CabinetmakerII
Feb 26, 2017Explorer
Krusty wrote:
There is a service bulletin related to that noise. Article 13-10-7. Updated vacuum harness part# BC3Z-9D430-E
By all indications by the trouble shooting in the TSB, this should be the solution. I ordered that part number and included the VIN. I was contacted by the company and advised that was the wrong part for my truck. I authorized the switch (which was less expensive) but when I went to replace the part I discovered quickly they did not send the correct one. The one they sent only has 2 connections. The part pictured has several and looks like a spiders web.
That said, I makes no since to me that "if disconnecting the hose stops the noise, then it is the waste gate solenoid" and they fix the problem with a replacement hose vice a new solenoid. No wonder I was a cabinetmaker and not a mechanic...
Thanks for the input!
