Majja13's avatar
Majja13
PP/HA question
Ok i have wondered this for years, and I have never seen one of these mysterious creatures in the wild, so I figure it is time to ask this question.
I know there have been times that I disconnect my sway/ weight distribution bars because I am going to be introducing a lot of roll between the truck and the TT. I know that in some cases people that have not done this end up twisting the TT. I imagine that you would want to sill perform this same action with The PP/HA. Am I thinking that is possible or am I way out in left field?
IF you are not sure what I am talking about here is an example. I am turning off of the main road into an unimproved are that drops away fairly sharply so the truck will be rolled right and down and the tt will still be somewhat level on the pavement.
Thank you
Matt
  • I've made turns like that with my old HA. In fact your description pretty much fits the turn into my driveway. I never disconnected anything and never had a problem.
  • I use a BlueOx swaypro, and I never disconnect it for any specific driving situation, or even for backing up. It gets connected when I hook up, and it stays connected until I am completely parked and situated.
    I can't specifically address this issue with a propride or hensley, but I can't imagine I would use them any differently.
