leoshats's avatar
leoshats
Pro Pride 1400 hitch - need help
Hello everyone, I need any of your professional experience regarding to use the Pro Pride hitch please. One and half month ago the RV dealer has installed this PP hitch in my brand new trailer. 5 times I've connected w/out any problem and spent about 20-25 min. for each connection, but yesterday was the horrible day for me.I spent about 3 hours ander the sun and the temperature of 95F. Point is that, the main hitch head changed the angle to down (will try to attach photos) and I couldn't to do anything to move the head up. I've adjusted the distribution bars, but everything was the same - the hitch bar stinger couldn't come in. I called to Sean (ProPride), sent a photos and he said "the only thing you'll need to use a bottle jack, get the hitch head up to level and you'll be able to back right in." Finally I have connected, but still DON'T understanding: 1. What happened with my hitch head and how can I fix this problem. As far as I understood this head's adjusting with the lift jack is abnormal and what should I request from dealer to fix this problem?
2. Yoke of my hitch is very flexible, not stable, playing and changing the angle during the connection. What should I do to stabilise the hitch head and not allowed to change angle?
3. Also hitch head every time change angle from left to right and vice versa as well and not stable in one position (playing). Should I use the distribution bars to handle the hitch head?
4. Should I take the lift jack in each travel!?? It's very heavy unit and extra weight for my truck.
Please help me with your proffesional advice. We are staying now in camping and I didn't disconnect truck from the trailers hitch, since I'm very afraid to get this problems once again. After 4th of July Holiday will go to dealer. I greatly appreciate in advance your help and support. Best regards, Leonid
