CaptPicky wrote:
Go buy you a multi-tester at Wally World or Radio Shack. Start at the beginning. Make sure your wiring connector on your truck is working. Test each connection. Then start working your way down the line towards your trailer. There probably is a broken connection somewhere along the line.
I got a tester and started at the tv connection. With the lights ON on the truck, two pins read between 50-60 volts and the rest were zero. So this must be a problem with the fuse on the TV then? I found the fuse box near the engine, and found which two fuses control the trailer hookup, but not sure what to do next.
Do I replace these? Should I just take my truck in to the shop? (I tried to get the fuse out by tugging lightly, but it didn't budge and I didn't want to break anything)
Thanks again
