TECMike's avatar
TECMike
Proflex removal
What are you using to remove Proflex that has dried on a trailer joint. The dried Proflex is about a year old.
  • I have to admit I've never heard of "proflex"? I thought that was a home gym built out of big rubber poles.
  • Does this proflex caulking turn hard as a rock? I have some caulking on my camper that a previous owner did and its like cement now.
  • I've used Bug and tar remover, but it's time consuming to clean the ProFlex
  • When I called Geocel about it a year or so ago they recommended mineral spirits and that seemed to work fine.
  • Last time I cleaned some off I use Mineral Spirits on a rag it worked great.
  • ProFlex is a real pain to get off. The best thing I have found is to soften it up with WD40 and use a plastic scraper to scrape it off.
