Turtle n Peeps wrote:
Now, for lets say half load on your genset you will get somewhere around 9 hours out of a 20LB tank. (about 10 to 15% less on propane then on gasoline)
Be aware a genset can't produce the same shaft horse Power on propane that it can on gasoline. IOW's if you max your genset out on gasoline you will be short on power with propane.
Ah, interesting! That's helpful! Yeah, that's the kind of info I'm needing. So somewhere over 4000w would be better than the 3100w ones I'm seeing if i'm looking at propane?
