kevden wrote:
I bought a champion 76530 3500w lp generator last year for the same reasons as you. We tow with an suv. I did not run the generator long enough in one trip to use a full tank, so i cannot answer that question. The only problem that i have is that i left the generator(minus the lp tank)in the back of the yukon all summer, and now the truck still smells like lp gas inside several months later. I plan to try some odor absorbing products.
For the initial oil fill in the spring i used penziol pure plus synthetic and when i changed the oil in the fall it still looked like new oil. Amazing how clean the lp burns. I also like that their is no varnish/gumming of the carb and fuel lines or ethanol phase separation.
You should try an Ozone generator. They work wonders on bad smells. Just don't sit in there with it.
