joerg68
May 21, 2022Nomad III
As a european ... every country here has their own legislation and there are a number of different fittings and adapters out there.
Typically, an empty tank is echanged for a full one (at a campground, home improvement store, supermarket or gas station), and refilling or even doing that yourself is unusual or even prohibited in many countries. Of course, the tank needs to belong to the local system, sometimes even the correct vendor chain.
Also, the dimensions of our euro tanks do not fit into US camper LPG compartments, euro tanks can not be laid on their sides, and all other sorts of discouraging technicalities.
On the other side, many countries/regions have LPG readily available at many regular gas stations, but others not so much.
If you have the correct fill adapters for an american tank and the three common automotive LPG systems, it is technically not a problem to fill your tanks at a gas station that sells LPG. Do not overfill and you are good to go. But it may be prohibited where you are, and the gas station personnell may or may not care, so it is up to you which risk you want to take.
