happy2rv
Nov 26, 2019Explorer
badsix wrote:
I would think your heater is not going to run continually. it should heat up then shut down then when temps drop inside it will come back on. like on for 5 min. then off for 5min. depends on how well your insulated.
Jay D.
I think he was trying to figure out "worst case". Agree if it runs all the time, that means its never warm enough to satisfy the thermostat. Assuming that the thermostat is set to anything below about 90, and temperatures are anywhere in the 0+ range and the doors and windows are shut it shouldn't run all the time.
There are a lot of things you can do to help. Insulated plugs for the ceiling vents, insulated covers for the windows, etc... Also, if you have 30 or 50A service, ceramic or oil filled electric space heaters can help stretch the propane. We don't typically camp in weather that cold, but we do use ceramic heaters along with the faux fire place electric heater even in 25-35 degree weather. We're already paying for the electric and filling propane bottles is a hassle.
Another thing to think about is liquids in all forms. Obviously water freezing is a concern. If you don't have an insulated and heated basement, you can easily get frozen water lines even with the RV being heated. Any water lines that run near outside walls can suffer the same fate. Our TT has an insulated basement. We disconnect all external hoses and store during sub freezing temps and haven't had a problem with internal plumbing. Other liquids to think about are batteries. Charged batteries shouldn't freeze, but if you run them down they will. Other liquids would be anything stored in outside unheated storage compartments...
44,071 PostsLatest Activity: Aug 30, 2026
