93Cobra2771
Jul 18, 2016Explorer
mbopp wrote:
I have an opinion on electric stabs and it's not favorable. The same mechanism that lets them adjust for side to side height differences also allows the TT to rock on its centerline.
I put an automotive scissors jack under the frame in front of the front axle, almost under the steps. It goes a long way to stabilizing the TT. Actually, I leave the door side a bit low when levelling and use the scissors jack for the final adjustment, then run the electric stabs down.
Yep, without some type of JT Strongarm or similar, the electric stabs not only wiggle side to side, the same wiggling will loosen them.
I use a couple of the aluminum adjustable stands right in front of rear wheels, helps tremendously until I do JT strongarms.
