myredracer
Jul 18, 2016Explorer II
If you have electric "stabilizer" (haha) jacks then you need stabilizers for your stabilizer jacks... :M The elec. stab. jacks simply do a poor job of stabilizing. If you watch one of them while someone walks up and down the entry steps, you will be surprised to see how much they move around. Elec. stab. jacks are inherently worse by design because the foot pads are significantly closer together compared to scissor jacks. The only good thing about them is the convenience. Sometimes the jacks aren't in ideal locations because of obstructions like stairs for ex.
Adding BAL Lockarm struts or equivalent do a decent job of reducing side to side movement. I installed a pair at the rear and they help a lot. The tongue jack helps to provide some stabilizing at the front and I don't think adding them at the front will help as much, plus it's harder to reach the nuts to tighten them. You can buy just 2 BAL jacks and the others are a set of 4.
If you have X-chocks, you'll be left with vertical movement to address. Bottle jacks or aluminum stacker jacks will work. I bought a set of the stacker jacks but only used them a couple of times because they only extend up to max. 17" and our frame is 24" off the ground. It was too much of a bother to lay down some cribbing each time plus the hassle of storing it all in the back of the truck.
Adding jacks just ahead of the wheels can help depending on length of the trailer and frame strength. Some have added a pair of scissor jacks and that's what I would do.
The photo shows how I installed the Lockarms. First, if you install any make of stab. struts, you will need Lippert's adapter kit p/n 314597 which extends the foot pads down otherwise the arms hit the jacks. If you mount the lower attachments to the jack pivot bolt, there is still some "slop" that allows some TT movement. Mount it to the lower bolt on the new Lippert bracket. In my case, I mounted it to the foot pad as I installed permanent larger pads to the OEM foot pads. I mounted the upper end of the struts to the bumper. It provides some fore/aft reduction in movement but I had to anyway as there was nowhere else.
