JIMNLIN
Feb 23, 2018Explorer III
Most 18"-20" OEM wheel load specs I've seen on the truck mfg websites can be in the 3400-3600 lb range which doesn't offer some one with a one ton SRW truck much load gains advantage by going to a larger capacity 18"-20" tire. The gain is just a bit more reserve capacity above the lower OEM wheel loads.
