jus2shy
Oct 22, 2017Explorer
For clarification, are you coming from the bottom of the image, or the top? Coming from the top, I don't see to big an issue. You'll get close to jack knifing but it shouldn't be too bad. As long as you match the tires on the trailer with the telephone position and swing hard/aggressively. Especially since you have an angled yard, so you don't have to go all 90 degrees on that (looking like 70 degrees by the pic). Coming from the bottom, it looks like you'd have about 110 or 120 degrees to contend with. Now that's a tough proposition.
I've been in tight spots with parking aircraft using the nose or tail of any push-back tractor. So that's my backing/parking experience. It's all about placing that tire around the object you want to pivot around.
44,066 PostsLatest Activity: Oct 04, 2013
