2012Coleman
Oct 23, 2017Explorer II
From the info the OP provided, I was able to pull this up on Google Street View. Looks like you will be coming the correct direction to me - the gate will be on your left - correct? Use a method called The Scoop. Looks like you will also be able to use the driveway across the street.
Practice make perfect - you should be able to get this in that yard - just have some spotters with walkie talkies so you wont crash into the fence.
But If I were you, I'd modify the fence by adding a gate so that you could back in from the front side of the house.
On edit, I "drove" around to the front of this house and see why you can't do that.
44,066 PostsLatest Activity: Oct 04, 2013
