tls5150
Sep 10, 2019Explorer
Pulling with 1/2 ton
Looking for feedback on trying to pull a rockwood ultra lite 26’ with a 2014 z71 Ltd 4wd, with 3:42 rear end. Dry weight of the trailer is 6300lbs. Any advice?
Desert Captain wrote:
I would bet that the tow capacity you have forgotten is far higher than any number you can actually tow without compromising max payload.
am1958 wrote:Desert Captain wrote:
So what is "odd"? :h
We both had rigs that towed well at or near our payload limits. What was your alleged towing capacity? I'm guessing Ford told you it was 9K# or more but we both know better.
:C
What is odd is that you say 6500lb "is all it could handle" which, to me, implies that anything more and the rig becomes unwieldy or unable to pull efficiently yet I'm pulling 1000lb more than that and find it all very manageable. Not saying you are wrong or anything just observing that our separate experiences are so disparate.
I can't even remember what the tow rating is but I know it was way more than I'd ever want or need.
time2roll wrote:
That is the method to my madness using GVWR instead of dry weight.
TurnThePage wrote:So you are fine and it does show how easy it is to go over the trailer GVWR.time2roll wrote:I'll have to be approximate.TurnThePage wrote:What is your trailer dry weight, actual weight and GVWR?
In reference specifically to half ton towing, why do people say, "use the max trailer weight?"
Some trailers have 3000 lbs of cargo capacity (Who's going to use all that?!). Some have under a 1000.
Even with excessive amounts of tools, backup parts, winter supplies, summer supplies, extra battery, solar panels, various added accessories, food, 50 gallons of water, grill, camp stove, camp table, camp chairs, cast iron pots and pans, and assorted other sundries, I can't seem to get over about 1500 lbs of stuff in my trailer.
What is your towing capacity?
Dry weight: 4800 lbs
Actual weight: 6100 last time weighed, as high as 6500 lbs
Trlr GVWR: 6000 lbs
Ram half ton towing capacity: 10,600 lbs
I don't think you will find a trailer that can be towed by a 1/2 ton with 3K carrying capacity. 1500 seems more the norm (and I've been looking at this lately).
mnaquaman wrote:
I run a 1/2 ton Chevy Silverado, 3:42 gears, 5.3L, and all of the towing options pulling a Jayco 23BHM that has a max weight of 6250lbs.
I try not to exceed 75% of the vehicle tow capacity.
Why 3:42 gears - there are in the middle, not stump pullers and not mileage gears! I can pull the mountains - I might not be able to blast up them at 65MPH but I can get up them!
