Alberta_Born's avatar
Alberta_Born
Pulling with half ton!
Hey gang. New to the site, and surprisingly for being Canadian, new to RV'ing. Just buying a 2007 Jayco JayFeather 29D. GVW is 7050 lbs. My question for you experienced towers is this: I have a 2006 Chev Avalanche (don't judge me, normally I'm a Ford guy), it is the 5.3 V8 1500 and I am almost certain the gear ratio is the 4.10. What can you tell me about using this truck to pull my about to purchase 29' featherlight TT? Thanks for your wisdom!
  • I used a Dodge Dakota WITH 3.92 gearing to tow a 6800 lb. trailer and yes on hill I had to kick the trans down but it still pulled hills at 55-60 thru the Catskills in Eastern NY. For a novice tower though I would not recommend it.
  • My first TT was a jayco jayflight 29 footer, about 5500 dry and 6500 loaded for trips. Might have pushed 7000 lbs the odd extended trip. My tow vehicle was a ram 1500 with 3:55 gearing 2wd. Truck was decent towing/stopping but even with an equalizer brand hitch properly matched to rig got occasional sway with passing semis/busses. The 3:55 gears was a mistake as hills and headwinds taught me what white knuckle driving meant! Im thinking you will have a decent setup with your gearing but may not enjoy all aspects of towing. Get a good hitch, learn to do proper set-up on it and dont overload your rig on the may long weekend. Get out and give it a try...and trust me 7000 lbs should never be called a featherlight! Enjoy the rig, and welcome to the site.
    Daryll
