Alberta Born wrote:
Thanks Soundguy. Just yesterday I called the local Jayco dealership here in Calgary and explained this all to a technician. He recommended a standard Reese Pro-Series Equalizer, and then later if I felt it was needed to add anti-sway. He thought the Avalanche would do okay with that.
There's nothing wrong at all with using a basic
Reese Pro Series WD system but it should
include a friction sway bar. The downside is 6 holes have to be drilled into the trailer's A-frame to mount the sway bar frame plate but nonetheless there are probably more of these in use than pretty well any other system, because of the cost. Personally I prefer WD systems like the Equal-i-zer and Blue Ox Sway Pro that feature sway control as a function of the design of the system and therefore don't require the use of a separate friction sway bar but of course they're much more costly.
I picked up my trailer on Tuesday and borrowed a friends 3/4 ton GMC. Since I don't yet have a sway system I pulled the trailer out of Calgary to my storage place with just the ball hitch. It pulled really well, no sway, handled bumps nicely all with just a ball hitch. But that's with the 3/4 ton.
The difference here is the 3/4's much greater payload capacity and much stiffer suspension compared to a 1/2 ton, especially an Avalanche which has coil suspension instead of leaf suspension so it can ride more like a car than a truck. Certainly with the size of trailer you've chosen your Av's payload capacity (or more correctly lack thereof) will be your biggest problem. That 4.10 axle ratio you've now confirmed will help enormously in terms of how well your Av tows this 6500 lb trailer, certainly far more easily than my Av with it's 3.42 would. Always use Tow / Haul for towing but heck with 4.10 you might even get away with towing in Drive instead of 3rd as I always do towing a lighter trailer. One way or another, you'll know for sure once you start towing with it. ;)
