hrose's avatar
hrose
Pump and filter for filling fresh water tank
Im mostly using my camper in the wild around lakes and rivers that ive been drinking the water from since im kid.
Theres 4 of us and we need a full tank of fresh water to make sure we got enough (55gal) for our 4 days trips, thats about 450 pounds that i could maybe avoid to carry for hundreds of miles on rough roads.
Id like to make a pumping setup with a filter to make sure nothing get inside the tank but water.
Does someone have that kind of setup or any ideas of what pump/filters would work just nice ?
I dont mind starting the generator to run a 110v pump if thats makes the process a lot faster then a 12v pump
Thx.
  • Not enough space to list all the stuff I've eaten, inhaled, and drank. I worked in the largest petrochemical plant in Houston for 35 years. I know all of them....VCM, BPA, Benzene, Butadiene, etc.
    But I don't drink RV tank water. Jeez a case or two of bottled water will last for 4 days easy. Bourbon is 60% water.
    That's why I drink good Polish vodka.
    It is only 50%
    No bacteria gurantee.
  • SidecarFlip wrote:
    Thats snazzy. I like it. I can understand your water concerns. Last time I hunted in New Mexico for Mule Deer north of Rosewell and east of White Sands, our guide told us under no circumstances drink the raw water that was in the containment tanks that fed the cattle watering stations without using a Life Straw or some type of membrane filter. I just passed and carried bottled water. No way was I about to get Montezuma's Revenge. The lodge cooking (we had a Mexican chef) was wicked enough.
    The ceramic filter should, in theory, pull most of the cysts and micro organisms out but you need to pull the filter after every use and clean and bleach it. That stuff multiplies if left on the filter.
    I use our well water to fill my FW tank (it gets tested yearly by the health department and always passes but I add a bit of H2O2 to kill anything, just in case. Municipal water isn't available out here.
    Would it be possible to add a list of suppliers where you sourced your components?
    Long time ago, but looks like daltonusa.com still has similar choices for filtering.
    Yes have to keep ceramic filter very clean. Our SW New Mexico municipal water is fabulous stuff so I always start out with a full tank of our precious stuff.
    As for drinking, yes, but I want to be able to shower and not worry about what gets into our mouths. Also, why put contaminated water in the tank and have to bleach the heck out of it afterword.
    Rick
  • If you are handy with piping, you can re-plumb your camper to pump directly from the lake into system, without filling up the tank.
    I did that on my conversion when in Mexico campground supplied salty water, when I wanted to save water in the tank for better uses.
    In bus storage bay I had one of those 4- outlets garden manifolds and series of short hoses that I could reroute between 2 tanks, pump and city water.
    The campground water had poor pressure, so I plumb it to go via pump for boost.
    Had no neighbors close by to complain about vacuum in water faucets ;)
  • Thx for the answers guys.
    Your setup is great rickjo, its a bit too much for what i need,
    But your pictures gave me a good idea of what im gonna do.
    Thanks for sharing.
