kcstrom
May 11, 2022Explorer
Purchasing first TT, need a bit of sanity checking advice
I'm looking to purchase my first travel trailer. SO and I have narrowed down the choices to the ***Link Removed***.
This has all the main features we're looking for and I think should be towable by our truck okay. I'd like some sanity checking on this by others more knowledgeable and experienced in this area than myself.
Edit: Re-evaluated. New trailer I'm looking at is in this post further down.
Freedom Express 238BH:
UVW: 5314lb
Hitch weight: 694lb
Length: 25'9"
Truck:
2013 RAM 1500 4x4 Crew Cab 5.7L
Towing capacity: 6500lb
Payload: 1650lb
GAWR (rear): 3900
GAWR (front): 3900
Measured weight (rear): 2580lb
Measured weight (front): 3480lb
This was only with me in the truck and 3/4 tank of gas. SO and kids will add ~350lb total.
I am planning to get a 2 or 4 point weight distribution hitch. Unloaded TT is 81.75% of the max towing capacity.
The hitch weight was a bit concerning to me at first, but it seems like a properly adjust WD hitch should alleviate that by placing ~20% back onto front axles and ~20% onto trailer axles.
I would need to keep additional weight loaded onto trailer and truck bed to less than 1K lbs to stay under max towing capacity.
I live in a flat area, but am planning to drive to hilly areas (like SD and Wyoming/Yellowstone), so it'll see some decent grades.
This trailer is heavier than I originally set out to look at, but seems like we can keep within all the max weights with a bit of planning.
Am I making a stupid decision if I buy this and pull with my truck?
UVW: 5314lb
Hitch weight: 694lb
Length: 25'9"
Truck:
Payload: 1650lb
GAWR (rear): 3900
GAWR (front): 3900
