brholt
Aug 24, 2016Explorer II
fpoole wrote:
To clarify on the Leveling part...
I can't easily tell when the camper is "off" the truck or not with the jacks tied down. I typically is 'off' on one end, but still "on" on the other end, front-back-side. I'll level and then bring it back down onto the truck until it just shows, bubbly gauges, 'unlevel'.
That way it's level and sitting, for the most part, on the truck bed for stabilization. Leaving the jacks tied down for me is a little too iffy when trying to level it. Works well in high winds etc.
AGain, I'll try to use the Lego tire levelers, but they're only good for a few inches and not going to try to balance two of those on separate wheels at different heights.
Hope that helps to clarify it...
One easy way to check for the rear, while lifting with the fast guns attached, is if you have stable loads is to watch them. As long as the stable loads are engaged to the overload spring you are not lifting the truck.
44,068 PostsLatest Activity: Jun 21, 2026
