Bedlam
Oct 26, 2020Moderator
You just need to box a frame out up front so the camper wings do not slide into your tail lights. Some people store outdoor furniture or popups in this area while others store fuel, propane, generators or other items.
The CG and under camper support will be fine, so you will have no worries about these items. You may find your front tie downs are too far for your turnbuckles or the turn buckles interfere with the DRW fenders. Using Torklift's camper tie down relocation kit is the simplest solution, but some people will anchor off the front jack brackets instead. If the turnbuckle is still too short, you can add chain between the turnbuckle and tie down to get the additional length required.
