Skibane wrote:
^Excellent post, John - Thank you!
BobsYourUncle wrote:
Great write-up John. Excellent! :)
Nice to see someone knowledgeable post good sound info with pics to support it.
Thankyou Skibane and Bob. Bob, I do remember you rebuilding your camper from years ago.
Since we are on the topic of butyl versus putty tape, to help the cause, I'll add some more info I have found in my camper restoration efforts on the differences between butyl and putty tape.
Doing total camper restorations from water damage is a very large time-consuming process. There is a great learning in how all these leaks come about, and then how to make what was originally there, last longer, as there is too much work that has been done to not make it better, repeating what the RV industry used when the camper was built, is not good enough in my point of view.
There is a very large difference in bonding strength between putty tape and butyl. Think of this like wood glue, wood glue done right between two pieces of wood is stronger than the wood itself. If you try and break the glue joint, the wood will fracture before the glue lets go. I have found this very same difference between putty tape and high-quality butyl, the bond to the siding or molding/flange is very different. Where the bond is poor, leaks can more easily happen.
A little background to my learnings. This first camper I am going to show you, is the mine, the one in my sig. I had read the horror stories of failing siding seals on a camper in the 2007-time frame, and I tried to do something to slow it down on my camper. I started back in 2009-time frame using Dicor non-sag/non leveling caulk to caulk the moldings to the siding and windows and doors flanged etc. to the siding. I cleaned the black mold and dirt away from the exposed putty tape, once it dried, I caulked the exposed putty tape on front and rear corners, doors, and some windows of my 2004 T310SR Sunline camper. Little did I know back then how effective just caulking the exposed putty tape would be. I also had no clue how far advanced the putty tape failures already were ongoing, just not yet leaking too badly into the camper yet on my then 6-year-old camper. This camper was too big for the barn I had at the time to store inside. So, this data is from a camper living outdoors in the mid-west of central Ohio until 2013 when the new barn came. In Aug. 2016 I retired and took up a new somewhat extreme hobby. Restoring older water infected campers. I guess I like the smell of mildew wet wood…(yuk) I had no idea how far into this I would get as I am today as I now have done 15 water damaged campers being repaired for close friends and family.
I was also buying project campers for a song, 10-to-12-year campers that were from 2004 vintage when I started up to now, 2007 vintage. I now own 5 campers myself. These 5 campers were made at the same factory, and the same approximate time, using the same methods of putty tape on the siding seals. The difference was the owners who had them. All of them other then myself had no idea they were supposed to do roof maintenance, not alone siding leaks, as the owner’s manuals of the time never talked about siding leaks. The campers were in real bad shape water wise. The insides of the campers were good shape, but the walls, floor and ceiling were bad. Little did I realize how much my efforts to stop siding leaks in 2009 had such a positive effect on the life of a camper. I already did Eternabond on the roof of all the seams in 2009, so the roof has always been good on my T310SR. And the siding too other then a slide floor leak I inherited when I bought the camper used in 2007 and a lower front left corner leak that I stopped the leak in 2009.
I’ll explain in pictures as they speak for themselves. You will see the white Dicor next to the failing putty tape, the Dicor saved me in this case. Three years ago, I took this front left corner apart to add diamond plate to the bottom siding section and deal with what little rot was in that lower corner from long ago.
I am heating the molding and joint as I remove the corner molding. You can see the Dicro on the edge and the putty tape unfolding from the corner seam.
Now lets look at the front side where roof water runs down the left corner.
You can see, I stopped an active leak path in the corner in 2009 with the Dirco. That putty tape shrunk and released from the siding and the molding in 6 years time and a leak path was well on the way to letting a lot of water into that corner. If it was not for the Dicor I did to stop the leak, I would have had a real mess in a few years.
Here is the back side of the molding. You can see the black mold/dirt water path. And the molding where the putty tape totally released from the molding when I took the molding off.
The point I want to make, putty tape does not create a strong long term bond to the moldings/flanges or the siding. It unfolds intact in chucks when you take the joint apart. A large percentage of the putty tape is totally intact from the siding or molding when you dismantle the camper. The bond to the siding and the molding is poor.
Now, lets look at the same type of corner on the camper I am restoring right now. This friend of mines camper is a 2007 model on a seasonal site. It did get covered every winter for the last 6 years he owned it, no idea what the prior owner did. Four years ago I told him if he wanted to keep his camper a long time, ideally you start with the corner moldings, remove them, scrape off the old putty tape and install new fresh butyl. Then work your way around to every siding seal. Sadly he was late in the game, he only pulled the front two corners off at age 11 years and reset the putty to butyl. He had a lot of water in the camper at that point and he never made it to the rear corners, cargo doors, slide etc. thus why I am restoring it now.
This is what commercial grade butyl looks like when you remove it from a corner joint at 4 years of age. I told him to use Permatite 250-H Butyl and he did as that was what I could get at that time.
http://permatite.com/tapes-permatite-250H.php
Here, I'm in the process of opening up the front wall.
As you can see, the butyl bonded very strong to the siding and the molding. The butyl had to rip itself apart for the molding to come apart. The bond to the siding and the molding is stronger then the butyl itself. This is why I say, use good commercial grade steel building butyl. This is not sold in the RV stores, they sell it in the building industry. The butyl is cheaper then the putty tape at the RV store and the performance is superior.
Here are the back corners of that same camper, still on putty tape, he never made it to changing them.
While I only have a sample set of 15 campers I have taken took apart, including, Keystone, Coachman, Gulfstream, and Sunline, all of them used putty tape, and all of them had putty tape failures that had broking bonds to the molding or siding. None of them showed the bond to the siding or molding like the butyl I showed above.
I have lots of end results of failed putty tape pictures if you want to see them. Here is some of them online in my Flick'r photo site.
https://www.flickr.com/photos/camper-johnb/collectionsHope this helps,
John
