Kayteg1 wrote:
Again, you need to compare particular truck as generic conclusion will not get you far.
I can't imagine any TC on the market can put more than 6800 lb on rear axle like my camper did (with some rocks collection and beer help).
The 2017 F350 dually handles it perfectly and I had no problem to shoot 80 mph when I needed.
Actually with normal, slightly lower load the rear was still higher than front and I have to put 2x planks under front wheels to level.
I also tow light boat with it, so the only reason I could see for F450 would be 7000 lb trailer.
The reason the 450/4500+ even came up is the lack 350/3500 availability on the market right now. There are a few GM 3500s available, but they are pushing into the $80,000 range. You can't even order a moderately priced one because electronic components are going into the highest priced trucks. They're putting lots of useless options on right now to escalate the MSRP.
