mattyj wrote:
I need something I can air down because we will be going to the beach with the camper on.
Well there you go. You’ve identified your “Can’t live without it” feature. If I were in your position, I’d be looking for an F350 as well.
Tighter turning radius might not be of any value to you either. Before I started buying F450 pickups, my last F350 was a ‘95 CC DRW, and the turning radius was just horrible. But I lived with it just fine, and the truth is, today’s F350’s turning radius is probably better than the ‘95 was. But the F450 pickup’s turning radius is even better.
I’m never on a beach, but I spend enough of my off-road time on roads that can do serious damage to tires that having the 19.5’s is important to me. The turning radius is also greatly appreciated when I’m maneuvering in tight areas. My own driveway and yard is one of those areas.
As far as payload capabilities go, the F350 only has the advantage if you insist that the 14K GVWR actually means that’s all it’s capable of. I’ll put it this way: put a 6K lb TC in the bed of an F350, and a F450 pickup of the same year (except for the 2011-2014’s) and the F350 is closer to its true limitations than the F450 pickup.
