Tennessee_Nomad's avatar
Jan 03, 2014
Question about electric tongue jack installation
My new tongue jack came today and I have a question. I gather that I have to prop up the camper at the a-frame in order to get the old manual jack off and get the new electric one installed. I have some cinder blocks that I can let the camper rest on while I change the jacks out. My question is... will the cinder blocks hold the weight of my camper while I do this? the dry tongue weight is around 450lbs I think. It may be a bit more with full propane tanks and "stuff" in the camper. The camper is a 2013 Skyline Nomad Joey 260
Any comments are appreciated... Thanks!
-Doug
  • I am like the others, hook up the truck and you have the best platform to work with.
  • michers wrote:
    Just put the stabilizer jacks down. Since you mentioned a TT, most are scissor jacks and rated at around 5000 lbs. I've had to do this myself once for an emergency CG repair and I've also used them to support the entire TT when I repack wheel bearings.
    Correct answer. Jus raise the tongue to where you want it. Drop both front stabilizers. Install the jack, and raise the stabs back up.
  • the bear II wrote:
    How about hitching it up to the tow vehicle and then remove the old jack.
    Instead of cinder blocks use a stack of 2X4s stacked log cabin style
    Or go to a local auto store and get a jack stand
    DanKirk wrote:
    I just hooked mine up to the truck when I installed our jack.
    That is how we did it, just put it on the hitch on the truck.
  • Just put the stabilizer jacks down. Since you mentioned a TT, most are scissor jacks and rated at around 5000 lbs. I've had to do this myself once for an emergency CG repair and I've also used them to support the entire TT when I repack wheel bearings.
  • I just hooked mine up to the truck when I installed our jack.
  • How about hitching it up to the tow vehicle and then remove the old jack.
  • Cinder blocks are incredibly strong. They hold up houses! I would make sure they are oriented the right way (hollow side vertical). Also, maybe place a 2x6 across the clock to keep it from scratching the frame.
