Atlee wrote:
Why doesn't the Gross Vehicle Weight Rating equal the Gross Axle Weight Rating for the front and rear axle?
Take my F150 (heavy) pickup for example. The FGAWR = 4,050#. The RGAWR = 4,800#. Yet the GVWR = 8,200#. Why shouldn't the GVWR = 8,850#?
In your case, the reason why your truck is not rated over 8,500 lbs GVWR has more to do with the DOT class that it is in than the actual weight it can handle.
The US DOT(Department of Transportation) and EPA(Environmental Protection Agency) classifies on-highway vehicles in 8 different classes with class 2 being broken down into two different segments. The classes for the light duty(yes an F350 is considered light duty) are as follows;
Light Duty
Class 1: 0 - 6,000 lbs GVWR (small cars and midsize trucks)
Class 2A: 6,0001 - 8,500 lbs GVWR (150/1500 trucks and vans)
Class 2B: 8,501 - 10,000 lbs GVWR (250/2500 trucks and vans)
Class 3: 10,001 - 14,000 lbs GVWR (350/3500 trucks and vans)
The GVWRs for the rest of the classes can be found
here.
So as you can see, if Ford gave your truck a GVWR of over 8,501 lbs, then it would be considered a class 2B truck which is where their F250s are. The class system that we currently have was made a long time ago and in my opinion is outdated. There are some classes (like class 1 and class 2b) that most trucks that are in them are limited due to the class they are in rather than what they can actually handle. Keep in mind that for most manufacturers, their GAWR is the weight that the axles AND suspension/tire components can handle.
Take a look at class 1 midsize pickup trucks. Every one of the V6 models have a max GVWR of 6,000 lbs. This isn't because all the manufacturers got together and figured that was the most they would rate their trucks. It is because of the class those trucks are in is maxed out to 6,000 lbs GVWR therefore they cannot make it higher even if the truck can handle more.
Take a look at the 250/2500 trucks as well(especially the diesel trucks). Almost all of them are maxed out at 10,000 lbs except for a few with small engines yet most have a GAWR that would put them into the 11,000 - 12,000 lbs GVWR range. Again, this is not because all the truck manufacturers agreed to max their trucks out at that limit or even because that is all that truck can handle by its specs. It is because 10,000 lbs GVWR is the max each manufacturer can apply to their Class 2B trucks going by the DOT and EPA trucks classification system.
Yes, the system is outdated and you would probably see all 250/2500 trucks automatically raise their GVWRs without changing a thing on the trucks if the Class 2B was raised to 12,000 lbs GVWR, but that will likely never happen given the bureaucracy of our government. So your truck cannot be given an 8,850 lb GVWR even if it could handle it due to government regulations.
