Community Alumni
Apr 03, 2018Not applicable
Atlee wrote:
Should one shut off their gas furnace at home during the night when they are sleeping?
Can a water heater fail, and then burn? Sure. But what are the chances? If there was anything approaching a problem with water heaters catching on fire, we'd be hearing about it no end on this board, and other RV boards. But all I hear are crickets.
We used to hear volumes about trailer tires, especially the so called "china bombs" exploding all the time. But even then the % of users experiencing that was very, very low.
What % of water heaters do you believe actually burn?
I was responding to CavemanCharlie who didn't see a safety issue beyond carbon monoxide or the water heater blowing up. The fridge, furnace, water heater, stove, and oven are all designed to generate heat. There's always a risk of having a uncontrolled fire when using these items. One of the reasons why these things come equipped with a, albeit useless sometimes, fire extinguisher.
I thought it was a pretty simple point. The point of my post was not to debate if one should or should not turn your water heater off at night. I don't really care if you turn your water heater off or not, what tires you're running, or what you do at home with your furnace.
