Still_Searchin_
Sep 25, 2013Explorer
Well, it seemed the first time I did that at home, a lost a fuse in the truck. Now I unplug from truck while setting up TT and prior to plugging into shore power. I also check pedestal with a cheap electrical tester (3 lites) before plugging in, but also have a better tester plugged into 120v. outlet in trailer. Recently cheap tester showed 2 yellow lites (all good) but inside tester showed a ground fault code, meaning the ground from the pedestal was not there. Way back, older homes never had a ground at the outlets either.
44,025 PostsLatest Activity: Feb 18, 2025
