JIMNLIN
Jul 29, 2013Explorer III
cmack wrote:
I also have new Maxxis tires so I have to ask, do radial tires blowout in the same manner as bias tires? I hear bias tires blow apart and shred the wheel well, do radials do the same?
Sure they can and do as evident of all the ruined ST tire threads.
Many times the tire throws the entire tread belt leaving the carcass holding up the trailer. After a few miles the carcass finally looses air and finally starts to shred.
Or the tire actually blows out/slow leak from a nail/etc. If the driver didn't hear it or se the low tire while driving then the tire will start shredding after several miles at intersate speeds.
If your using a ST tire (any brand) I would get a good TPMS setup especially if you run at nite.
I've had all of the above happen with the old bias ply and the radials on my RV and mostly non RV trailers.
44,056 PostsLatest Activity: Nov 19, 2013
