Buzzcut1
Jul 15, 2014Nomad II
Couple of things. First fill it with fuel and go to a cat scale and see what you really weigh per axle. Second you true limiting factor is the tires and rims as you don't want to exceed the max load rating of those components.
Realistically the only way you can carry more load is different wheels and tires which is why folks go to 19.5 wheels and commercial tires. you won't exceed the mfg axle spec but you will exceed the GWVR and GAWR which is based on OEM tires and wheels.
44,071 PostsLatest Activity: Aug 16, 2026
