AH64ID
Jul 15, 2014Explorer
mkirsch wrote:Fishin'musician wrote:
Been searching for a tire with a higher load rating than 3064lbs, but can't find anything available for a 16x6.5" rim. And cant find anything other than the Rickson or Visions. Would like to be able to go to 17 or 18, don't really wish to spend a couple grand on new tires and rims.
You're not going to find one for a 16x6.5 rim. 245/75R16 Load Range E is the best you can do, and those are 3064lbs across the board.
A 255/85R16 will fit a 16x6.5" rim and they offer 3415lbs/ea.
A 17" wheel won't gain you anything, in fact similar sizes are often rated lower than a 16" wheel.
I went thru the debate on 18's or 19.5's and ended up with 19.5's. Very few aftermarket 18's are rated for more than 3200lbs and the ones that are cost big $$$$. Then 18" tires are $$$, so in the end the cost was very similar for 19.5's which are rated for 4500lbs and tires they handle weight much better and last longer.
44,071 PostsLatest Activity: Aug 16, 2026
