dadwolf2
Jul 19, 2014Explorer
ah64id wrote:
That works too, just remember they are quite a bit heavier than "dry" or advertised. My dads 2600lb camper is closer to 4000 fully loaded.
SO TRUE-my camper has an outside manufacturer's sticker @ 2359 lbs, and internal sticker after factory options = 2608 lbs,couple of dealer installed options and is closer to 4000 lbs fully loaded. I didn't order Rickson 19.5 Wheels until after I had gone to the scales. Initially I was hoping to save money and stay away from 19.5's but after camper was brought home (empty) and then loaded did I pursue the more expensive/safer option. I would suggest if possible, to bring the camper home, then load it up before deciding how much you need.
