Fishin_musician's avatar
Jul 15, 2014
Question.. Increasing payload on Silverado 2500HD Diesel
Howdy y'all! Newbie to TC'ers but I've been spending a lot of time on here trying to figure out what I can do to my truck to allow for more options in my search for a compatible camper. The truck is a 2003 Silverado 2500 Diesel crew cab short bed. Rated payload is only 1500 lbs. I initially was looking for a bigger truck but when dad offered me his truck with only 45k miles on it for $15k I had to jump. It's a nice rig, but it's going to need some help in the payload department. I would like to put some bigger tires on it to begin but I'm having difficulty finding any tires rated higher that 3064 lbs because of the stock GM rim size (16" x 6.5"). Thinking about putting an extra leaf spring on each side and maybe some sway stops, but I have friends who swear by their airlifts because they can manually adjust the lean. I'm also hearing from folks that if I go over my payload rating insurance companies will deny any claims....Sway Stops, Helwig Say bars, super springs, .............holy cow.
Confused in Boise, -GARY
  • ah64id wrote:
    I have seen first hand the damage that can be done to a spring pack by bending it where it isn't designed.. Especially at such a sharp angle.
    So engaging the overloads sooner is "A BAD Idea"?
    Do you have pictures of your first hand sighting?
    Was it Torklift Stableloads that would be in your picture?
    Was it a Ford, Chevy, GMC, Dodge, RAM, Toyota, or other?
    Inquiring minds would like to know.
  • trail-explorer wrote:
    ah64id wrote:
    Do 2500HD's have upper overloads?
    No, they don't.
    I'd recommend Torklift Stableloads before Airbags.
    It's a decision each owner has to make, but doesn't it make you wonder why torklift would warranty a part the don't make? Fatigued and stressed springs aren't something I want on my rig, even if they are warrantied.
    No, they don't.
  • Buzzcut1 wrote:
    Couple of things. First fill it with fuel and go to a cat scale and see what you really weigh per axle. Second you true limiting factor is the tires and rims as you don't want to exceed the max load rating of those components.
    Realistically the only way you can carry more load is different wheels and tires which is why folks go to 19.5 wheels and commercial tires. you won't exceed the mfg axle spec but you will exceed the GWVR and GAWR which is based on OEM tires and wheels.
    Excellent advice.
    There will be many posts telling you that you cannot increase payload, while they are correct some common since can be applied to your SRW 2500HD and you can safely and legally exceed the GVWR.
    The axle is an AAM11.5 rated at 10,912 lbs by AAM for SRW or DRW. IIRC the GM DRW RAWR is 9,350 so stay under that.
    19.5's will maximize safety and payload but may not be necessary, which is why scaling the truck is important. A 285/75R6 will get you 7,500lbs worth of tire, if the wheels will support it.
    Airbags and a rear anti-sway bar will help support the additional load.
    wcjeep wrote:
    There are E rated tires that approach 3500lbs +/-. Usually going bigger which then compromises stopping ability. 19.5" tires/rims are stronger but sacrifice sand ability. Before adding a leaf check out Torklift Stable Loads. Add Stable loads before airbags. The airbags may not be necessary. Airbags tend to unload the suspension.
    Do 2500HD's have upper overloads? If not I wouldn't run the overloads, they make the springs bend in ways they where not designed, far worse that airbags removing some weight. There is a reason that torklift adds a warranty to the springs..
    If airbags are properly used they help distribute the load to an additional point on the frame and still keep plenty of weight on the suspension. Letting the OEM suspension sag 1-2" from empty seems to be the best for roll control, load stability, and suspension movement. It also keeps a fair amount of weight on the OE springs.
  • There are E rated tires that approach 3500lbs +/-. Usually going bigger which then compromises stopping ability. 19.5" tires/rims are stronger but sacrifice sand ability. Before adding a leaf check out Torklift Stable Loads. Add Stable loads before airbags. The airbags may not be necessary. Airbags tend to unload the suspension.
  • Couple of things. First fill it with fuel and go to a cat scale and see what you really weigh per axle. Second you true limiting factor is the tires and rims as you don't want to exceed the max load rating of those components.
