d3500ram wrote:
If using a 1/2T pick-up, then maybe some of new cabover-less campers such as the Rayzor or the NorthStar Vista would be a better as far as weight concerns go.
Even those will put you over the rear axle rating on most 1500-series trucks unless you camp naked and hungry.
Sure you can add helper springs, airbags, heavier-duty wheels and tires, but all you've done is spend the difference between a 1500 and 2500 series truck.
There are people who have carried, and do carry campers that far exceed the weight rating of their 1500 series truck, without any issues that they will admit to. This is an online forum after all and you have to take everything that's said, even what I say, with a grain of salt. There is the distinct possibility that any or all of us could be misleading you either intentionally or unintentionally.
I personally cannot in good conscience recommend putting any truck camper on any 1500-series truck, simply based on the fact that it requires too many modifications to make it even workable. Others have a differing opinion. You have to figure out which you believe.
