Huntindog wrote:
ScottG wrote:
I've had both the friction type and a DC and there was no comparison. The DC is an "active" system that applies more pressure as needed and just does a better job of keeping the trailer tracking straight behind you.
The friction units worked OK for a few years but eventually wore out and would get contaminated with rain, road scum and grease and would eventually have little effect and get noisy.
The DC is NOT a active type sway control. It is a friction control. It utilizes friction somewhat differently. There are some threads that go into this in depth. Our resident engineer Ron Gratz is involved in most of them.
Yes I know about those discussions and both I and Reese disagree with them completely. Furthermore it's "active" because the spring rate increases as sway increases and the trailer moves out of line with the TV. You can lubricate the Reese anyplace you want and it has no effect on the sway control.
The Reese uses spring tension just as it describes in all it literature but I understand some people simply can't wrap their heads around it - but that doesn't mean that Reese is wrong.
That's it, I'm not going to argue with you or anybody else. If they really want to make such an argument then they should contact Reese.
Have a nice day.
