I wouldn't trust anything electronic or things with fans or transformers with a MSW Power Inverter... The BLUE SMOKE will get you haha...
In the older days the PSW Inverter cost alot more than the MSW type Inverters. You can get a good 600WATT PSW AIMS Inverter from Amazon now for $130 I think I saw on their page yesterday...
I use the AIMS 600WATT PSW Power Inverter in my off-road POPUP trailer. What I did was run two multi-tap outlet strips extensions cords from the Inverter with one going to the home entertainment area and the other cord going to a table top near our sleeping bed... These extension cords have a ON-OFF switch on them... We can power up all of our small wattage items we use everyday with this setup and not ever worry about them going up in the infamous BLUE SMOKE...
Google Image
My AIMS Power (PWRI60012S) 600W Pure Sine Power Inverter is mounted as close to the battery main switch and still be inside my trailer... I actually leave it ON all the time when we are using the trailer...
My small items usually only pulls around 250-300WATTS from the inverter usually between 6PM and 11PM each evening when camping off-grid... This is about 25AMPS being drawn from the 12V battery bank...
It is sure neat for us having the PSW Inverter around when we are not on shore power or generator... We make it through the night just fine and by 8AM the next morning my battery bank is around 12.0VDC close to the 50% state of charge. Then I will run the 2KW Generator with the trailer shore power cable connected to it and re-charge my battery bank back up to its 90% charge state in around three hours og generator run time. We good to go agin the next day/night run off the batteries...
Been doing this routine since 2009
Works out good for us...
Roy Ken
