WarrenS65
May 02, 2023Explorer II
I have 2 206Ah SOK batteries, a Victron SmartShunt, and a Victron Multiplus 3000 inverter/charger. The two batteries are connected in parallel with the negative going to the SmartShunt and the positive going to a battery disconnect switch.
The other side of the shunt and switch are connected to my bus bars with the MultiPlus, Victron Orion DC/DC converter (2 of these), Victron MPPT controller, and the 12V wiring going to the camper.
The SOK batteries have BMS with Bluetooth. I was having "trouble" with the SOC on the two batteries and the Victron all being different. I called CurrentConnected.com (where I bought the batteries and most of the other Victron components), and they had me disconnect one battery then discharge it and recharge it twice, then repeat with the other battery. After this, I reconnected both batteries and everything is working well.
My advice is to buy all your components from one source that will give you good support.
I also have the Victron Cerbo GX and it's connected to my router. I get e-mail alerts when the batteries cross thresholds I've set, but with the solar panels, I haven't had to plug it in since March.
