StirCrazy
May 04, 2023Moderator
3 tons wrote:
Follow-up to WarrenS65:
When it comes to accurate SOC’s, I kinda see the Bluetooth feature mostly as marketing gimmickry, while their real utility is for checking individual cell status…Further, it remains to be seen how the Bluetooth will respond to two batteries in parallel or series connection…My view is there’s no substitute for the credibility of a Victron shunt based meter..
Of all possible features, the Bluetooth feature wouldn’t be high on my ‘must have’ list - JMO
3 tons
The biggest issue here is different companies use different BMS, and sometimes even the same company will change their BMS if they are not in stock and are running out. Hopefully if this happens the company will list a different model number and let you know if it is compatible with the other BMS they have used. Most are not. It goes the same for mixing different sized batteries or exceeding their limits in series or parallel.
Then you must throw in the fact that some BMS' are better than others. but all of them should be decent at SOC as that's what they base their protection on, so that would never be one of my concerns. a cell drifting out of spec because of partial charging and lack of top balancing would be more concerning to me.
I like my Bluetooth in my camper, do I used it for looking at the capacity remaining, not really, as my phone is pretty must put away when I am in the bush, but I do use the Bluetooth and my phone to look at it once and a while and when I need to change the charging profile. for that it has been a godsend as when I want to do a cell balance, I just switch user profiles in the BMS by Bluetooth, then when it is done balancing, I put it back to the 90% cap. same with the day before I leave for camping, I always take it from the storage voltage to 100% to make sure everything is balanced before I leave. I can do that from my chair in the morning while I am watching the news.
Steve
