Sterling1
May 04, 2023Explorer III
mbloof wrote:Sterling1 wrote:
For now I plan to use a volt meter I have installed in my camper for SoC level which should be good enough for my use. I've "calibrated" the camper meter with a multimeter at the batteries when the isolation switch is switched off to eliminate parasitic draw. So far there no significant difference between the camper volt meter and the multimeter but I haven't taken measurements when the batteries are in a low SoC.
Good luck with that. As an example on my NL that switch only breaks the connection to the Converter/charger - the jacks+controller and fridge are directly connected to my battery(s) bypassing that switch.
- Mark0.
On my camper everything gets disconnected from the batteries by the switch other than the generator and inverter which are connected directly to my batteries.
