aftermath
Oct 21, 2014Explorer III
I would most definitely blow out the city water. There is a check valve that can retain water. Some have had this freeze and cause trouble. If your manual says to blow out the flush line then I would do that. Make sure you keep the pressure down to around 50-60 psi unless the manual says otherwise.
