b_rharmon
May 20, 2018Explorer
Looking at some images of the same year and model, there is no sign of the access door outside for a water heater. I see the furnace vent and water tank fill cap. The unit I saw has a battery and propane tank.
By the way, the roof on your son's trailer is not the style that had problems with delamination. But always check for leaks and water damage which might indicate the need to re-caulk.
There is probably no water pump but a manual pump to get water into the sink. That was the way it was done on older trailers.
