bobinyelm
Oct 12, 2014Explorer
Questions about Arctic Fox 30U Storage
I am asking this for some friends who bought a used 2003 Arctic Fox 30U a year back.
They moved to the Chicago area and will be storing the trailer for the foreseeable future as their plans to "full-time" were ambushed by the arrival of a grand-child, so are moving into an apartment to help their daughter raise the child for a few years.
The believe that because it is an "Arctic Fox" it is impervious to freezing or water intrusion and rot (because they believe it is only fiberglass and aluminum-no wood members or plywood anywhere). Obviously, AFs are well insulated, but I also know insulation only works if enough heat is supplied to the interior by the furnace (ducted to plumbing areas) to keep the interior above freezing.
I just had a leak in MY 2007 Forest River do considerable damage before being discovered (or noticeable, even), and it also has an "almuminum framework" and is covered with laminated panels with FG (Filon) skin as I understand the AF uses (though much MORE insulation).
My pleas for them to check and caulk their seams (as necessary) at least every 6mo are falling on deaf ears, and before I get more vocal, I wanted to ask here about Arctic Fox to see if maybe I am being alarmist. Maybe AF trailers ARE "bullet-proof," but they frankly look pretty similar (though certainly a step up from my Wildcat unit).
They will be leaving the trailer in an unheated storage lot near Chicago over the winter, so maybe someone WITH an Arctic Fox can offer their suggestions as to what needs to be done to allow the trailer to survive a couple years or so of relatively unattended storage.
At a bare minimum, I am getting them to install a winterization valve to introduce RV anti-freeze into the water supply lines, and throw a bit into the traps, fresh water tank, and the waste tanks so the dump valves won't freeze.
If anyone has a link to a "cut-a-way view" of AF construction showing the materials, it would be appreciated as well.
These are NICE folks, and I don't want to see them end up with large repair bills.
Thanks,
Bob
Thanks,
Bob
