robsouth
Apr 17, 2014Explorer II
rainy029 wrote:Weight distribution bars are used to help move some of the weight on the ball of the hitch to the front axles of the tow vehicle. This helps you remain level, and take weight off the rear of the truck. Sway bars are of two types. Friction control is a supplemental bar to the WD bars and depends on friction to help keep the sway to a minimun. Some WD bars (equailizer hitch, etc have the sway control built in so you do not need extra friction bars.
Had our first trip with our "new" (to us) TT. Have a few little details to work out. One of the issues is our dogs and the door. We need to put something on the bottom half of our screen door to keep the dogs from "running thru" the screen. I don't want to block airflow though. But will the outside door shut with something in there. The old PUP had the metal on the bottom so this wasn't a issue before.you can use plexiglas with holes drilled, hardware cloth, etc.
Our kitchen faucet drips. Like it doesn't shut off completely every time. It is a metal one. Do we need to get one made for a RV or can we get a house one like at Lowes?You can replace it with one from Lowe's, Home Depot etc. just measure the width between the cold and hot water feeds, or even better, take the old one with you.
And the biggest issue is... weight distribution bars or sway bars.. we know of them but not about them
The guy we bought the TT said we didn't need them. We think differently. We tow a 17ft tri-hull boat also. It doesn't have them. We took the camper to the same lake that we take the boat to. So we know the road and the boat trailer's pull on the truck. The camper did not sway from side to side. But when we went over the railroad tracks, or the bridges. It would "tug" on the hitch. Like bounce the truck. Not bad though. But it isn't smooth like the boat.More information needed here. Weight of camper, type of hitch in use, length of camper, etc.
What is the difference between weight distribution bars and sway bars? And how do we know what weight to get?
44,056 PostsLatest Activity: Nov 19, 2013
