goducks10
Dec 21, 2015Explorer
FWIW my Fox Mountain (by Northwood) was correctly wired for sat and cable. I found out by removing the outside coax connections and then removing the connection inside the 5er. One is white and the other is black. I was surprised I guess as I didn't expect it to be right. It would be nice if they would've labled the inside better. the outside is labeled sat/cable, but the inside just has two coax connections in a single wall plate with no labels.
Anyway to the OP I have the same exact layout in my FM 235. If they do things similar then there should be an access panel behind the TV for the shower plumbing. You could access the inside cable connections by feeding the sat cable down the interior access area that behind the TV wall.
