UuallyExplorerSep 05, 2014R V water pumpWhen we use our water pump we get a lot of air in the line, it spits & sputters. Have ckecked for leaks & found none. Makes it diffucult to shower or fill the sink. The holding tank is full. Any idea ...Show More
beemerphile1ExplorerSep 05, 2014Sucking air between the tank and pump. If you have a winterizing tube be sure it is tightly closed.
Related ContentWater pump?Water PumpWhy no hot water?Water pumpWater Pump Failure Traveling To The Eclipse
