ScottG
Oct 13, 2014Nomad
blderman wrote:ordually wrote:
TFLTruck did a Ike Gauntlet tow test of a 2015 Ram 6.4L 4.10.
Identical axle ratio and load (12.5K) to the 2015 Chevy 2500 they tested a few months ago. The Chevy gives up ~50hp and lb-ft. Surprising outcome.
I don't read the article as they weighed the same. I read it as they were within 100lbs of their GCVW. If that is actually the case then the Ram weighed 2,000lbs more. It still doesn't justify that 2nd gear is inadequate but it would definitely make a big difference.
That's a good point. If they weren't loaded the same then the results are meaningless.
44,068 PostsLatest Activity: Jun 21, 2026
