ib516
Oct 14, 2014Explorer II
ordually wrote:ib516 wrote:
Here's what was added by the guys from TFL in the comments:
Ram Truck “invented” the first gear hold feature – and calibrated it – to avoid gear hunting and driving at excessively high rpm’s.
Ike is a variable grade and we worked hard to develop a calibration that appropriately manages torque on the run and other grades.
We don’t want the truck to rev high for extended periods of time and purposely hold 4,200 rpm.
Seems like there's some designed in limiting by the PCM/ECM going on here.
Interesting. I wonder what the Ram powertrain engineering folks would say about needing to avoid more than a sustained 4200RPM. Cooling limitation? BMEP? Transmission limitation? Rating a motor at 5600 RPM and only using 3/4s of the HP is surprising. I wonder how the PCM would know to enforce limit, as it would be too obvious to do it on the 1-2 upshift, and way too obvious to just pull fuel from the driver when holding in first to bring RPM from say 5000 back to 4200. Perhaps only on the 2-1 downshift then it applies the 4200?
IB516--have you noticed any PCM/ECM limitations along the lines of what Ram described in your towings?
I have no idea why they designed that in.
I have never felt anything like it when using my truck to tow my 12k RV. Mine has downshifted to second gear and revved past 5000 RPM when going up mountain grades in the Canadian Rockies (7%) and accelerated. The grades weren't nearly as long as the Ike Gauntlet though. Also, I have never been above 8000' elevation yet with my truck either.
Mine didn't seem to gain any significant engine or transmission temp when pulling hard either (both are available in digital format right to the degree so they are easy to monitor), so I can't see it being a cooling capacity issue.
The 6.4L Hemi showed it's performance potential when tested against the competition on the Davis Dam grade (lower elevation) and in other tests done at lower elevations (Michigan) where it clearly outperformed the competition during the Pickuptrucks.com testing. So by that, I think it might have something to do with the extreme elevation.
It's all just speculation. What I do know is I have been very pleased with the way mine performs so far - towing and empty. In the grand scheme of things, we are talking what - 90 seconds over 8 miles?...and maybe only when at 10,000 feet? :?
44,068 PostsLatest Activity: Jun 21, 2026
