transamz9
Apr 19, 2016Explorer
IdaD wrote:
The coils ride and handle noticeably better, and I think part of that is the rear swaybar. The payload difference between the two is substantial on the diesel trucks due to the GVWR class limitation, but the axle rating is only 500 lbs lower on the 2500. In terms of real world performance there's not much of a difference. The biggest difference may be the TPMS on the 2500, which can be a hindrance in setting the PSI where you want it without the idiot light going off (or getting the trigger points reset by a dealer).
The performance can be quite a bit different when you look at the 2500 can't be gotten with the Asin and 900 lbft of torque. The 3500 can.
