Cummins12V98
May 16, 2016Explorer III
thecdnmole wrote:Cummins12V98 wrote:
The bags ARE carrying the load. The springs are there to control axle wrap and position axle.
There are two full length springs and two that go from the axle to the front spring support.
I feel the system is worth every $$$. The truck rides near level instead of AZZ high solo and rides level when towing no matter the weight up to RAWR. The ride is very nice.
Thanks Cummins, your picture helps as it was fricken cold when I looked and didn't have time to really check it out. I can see how the leafs that are there are more for stability and control. Next thing now is a test drive!
Make sure you lower the rear tire pressure to 35. My truck when it was delivered had 80 in the rear and 70 in the front and it was not a good ride! My truck is a Dually.
