Adam_R
Dec 20, 2015Explorer
SolidAxleDurango wrote:transamz9 wrote:SolidAxleDurango wrote:
Shocks should NOT be the limiting factor. They will get damaged.
The steel spring or limiting strap should be limiting factor.
What do you think the limiting factor is on the front of your truck with the coil springs? What about the rear on the new Rams with coil springs?
The coil itself.
No, that is not the case. As mentioned already, the coils will fall out if the shocks are a little on the long side. All of my rock crawlers use the shocks as limiters. No problems there. If I was off-road racing and jumping, I'd look at some limiting straps, but for my low speed world, shocks do the job just fine.
Adam
